NATS Key Antenna
7.7K views 2 replies 3 participants last post by  idrm350
#1 ·
Hi it seems I have a problem with this part and potentially needs to be replaced, anybody with any experience of doing this?
Can it be done with out replacing the ECU or does the ECU, antenna, and BCM all have to be replaced using parts from the same car?
Looking at a massive bill for the work if it all needs to be done so any knowledge of this would be great.
Thanks
Ian
#2 ·
If the problem is with only the antenna it can be replaced without having to replace the ECU or BCM. The antenna simply relays the signal from the key to the BCM. It's not coded in any way.
#3 ·
The antenna is around the ignition I believe. As Karl mentioned, it can be replaced separately.
