Bank 2 Sensor 1 Question
30K views 3 replies 2 participants last post by  karlh
#1 ·
Hi new to forum. Car throwing code Bank 2 Sensor 1. A. Is this the passenger side o2 sensor before catalytic converter? B. If so, is this the sensor that I can see inside hood going into exhaust just below motor or is it located underneath car? C. Do I simply unplug connector, unscrew sensor, apply a little anti-seize to threads of new sensor and rethread into hole? D. Do I need to disconnect battery to reset code or does it reset by itself? Thanks for any help.
#4 ·
Bank 2 is the driver side (US), according to the Service Manual.
I would confirm the exact code. For my 2005 Z, DTCs P1051 and P1052 refer to the bank 2 sensor heater. DTCs P1281, P1282, P1283, P1284, P1286, P1288 and P1289 all refer to the bank 2 sensor itself. The sensor could be at fault, but the problem could also be a wiring issue, a bad injector, low fuel pressure, an intake air leak, or other problems.
As I said earlier, you really need a copy of the Service Manual to accurately troubleshoot the problem.
#3 ·
Thanks for info. Code was checked two different times at Advance Auto and then confirmed at dealer. Long story on that.
So should I confirm exact code or is that satisfactory to determine problem? How do you determine which bank or side is affected?
I keep getting different info on what is the correct side. Thanks
#2 ·
A. For US spec cars, Bank 2 is the driver side. And yes, sensor 1 is before the catalytic converter.
B. Yes.
C. Yes. You should use an O2 sensor socket. Be careful with the anti-seize. If you get it on the the sensor tip the sensor won't work properly. Most quality replacement sensors come with anti-seize already on the threads. If you feel you need more, use a copper high temperature compound.
D. The code should clear itself, but it may take a few driving cycles. Disconnecting the battery is the brute force method. A good code scanner will allow you to clear the codes.
You didn't specify the actual trouble code number. I strongly recommend you get a copy of the Service Manual and check the procedures for your specific code. Sometimes other problems besides the sensor can cause an O2 sensor code.
