The following parts might shock some of you, but they are for real 800+hp setup, due to finacial problem, my project for twin-turboed G35 is not gonna work out....so i offer those who are really interested into performance this chance... BE QUICK before they are gone
They are all brand new and still sealed in the box, i'll post send photos upon request for some parts that can be opened easily to take photos, the rest will not be taken until someone is really into the deal, if u are in Brisbane area, i can meet you and discuss about it...
CP pistons (VQ35 20thou oversized; 8.5:1 compression ratio)
EAGLE H-beam rods
KOYO 36mm radiator
VQ35 ARP Main Stud Kit
VQ35 ARP L19 Extreme Duty Head Studs kit
Cosworth Stopper Ring Headgasket VQ35 96mm .6mm (good combination with the pistons)
JWT C2 Camshaft Set VQ35 (for forced induction)
JWT VQ35DE Valve Spring & Shim Kit
Cosworth Nissan VQ35 (3.5L) Main Bearing Set-Tri Metal (standard size, but gives stronger strength)
Cosworth Nissan VQ35 (3.5L) Rod Bearing Set-Tri Metal (standard size, but gives stronger strength)
Cosworth Nissan VQ35 Thrust Bearings Metal (standard size, but gives stronger strength)
Unorthodox Racing FullPulley Set (Crank, Alternator, and Water Pump with Belts)
JWT Lighten Flywheel and Clutch Set (for forced induction)
D2 coilover for 350Z/ G35
Project Mu brake pads (for Brembos)
Please consider the above parts are new, i spend more than USD$8000, now i only want AUD$8000 for them....
It is a real great deal, only once in a lifetime
please PM me for more details you would like to know
EAGLE H-beam rods
KOYO 36mm radiator
