Alright I started my install today and so far so good. I was a little scared since I've never done any audio installs before. :headshake:
Anyway I used the SEARCH function on all the boards and compiled all the necessary information that I needed. Chazz was also a tremendous help, he forwarded to me the instructions for the In Z PC, :thumbsup:
Taking the dash apart wasn't that too difficult thanks to the wonderful instructions by Scafremon
The only PROBLEM I ran across is when detaching the radio harnesses, theese are a PIA. :headshake: I finally did manage to get them off.
First order of business was to try and find the CONSTANT ON and ACCESORY WIRES. The larger plug out of the two is the power plug. The large YELLOW wire is CONSTANT ON and the LIGHT GREEN is the ACCESORY. I needed these to power the XM.
I simply tapped into these two wires.
I could have finished up after I did that but all the wires looked MESSY. So, I took some wire looms and covered all the wires. I ran the wires right along the exiting wire loom and zip tied them together so it's much cleaner.
You can see here where it was grounded.
I also took the excess wires and tucked them in neatly in the back wrapped in electrical tape.
