Can I place it on the rear strut tower brace and have good reception through the glass? Also how good does the wireless FM modulator work? I just bought the Roady2, not sure if i should keep it or return it.
I just installed mine and put my antenna right behind the rear wiper fluid sprayer on the roof. Its hardly noticeable b/c of its small size. I tried the rear strut tower but didnt get great reception.
Also I didnt use the FM modulator. I went through my radios aux terminal and just bought the adapter for it and also bought a stereo to RCA cable to connect to it so I didnt have ti use the modulator.
I had mine on the rear strut tower brace and got perfect reception but hated looking at it. You will get reception right through the glass. had mine moved to inside the rear brake light on the hatch. Can't see it at all and perfect reception!
i have an 04 enth. does that radio have the aux input? Also any documents on how to remove the radio? thanks
I am not sure about the stock radio as I have an aftermarket, but I know people with the bose system use a PAC cinverter. Your local stereo shop will be able to tell you how to do this if no one else on here knows how. Heres a DIY on on how to remove the stereo:
http://www.350z-tech.com/forums/tutorials/...0&CODE=02&id=24
