Window problem is probably a motor issue. Thy thumping the bottom of the insidde of the door with your fist while holding the window up button up to see if the window rises. If it does, then its a window motor problem. I've replaced my drivers side twice and passangers side motor once so far.
Your central locking from inside the car will not lock the drivers door, but will lock the passanger door and hatch. If this your problem, then everything is normal.
