Windows and central locking not working!!!
259 Views 3 Replies 3 Participants Last post by  dkmura
Hi guys so my windows won’t auto go down or up, the passenger side window isn’t working and cereal locking from the inside isn’t working doesn’t anyone know what could cause this???
Many thanks
Have you checked to make sure the window lock isn't engaged? That prevents the windows from opening or closing and is easily engaged by accident. Next, you may need to pull the DS door panel to see whether the central control panel is properly connected and working.
Yes. This happened to me. Even took it to the dealer and got an outrageous quote to repair. I noticed that I accidentally had pressed that switch. Problem solved.
Did this turn out to be a problem with the central window lock?
