1 - 20 of 69 Posts
http://auto.howstuffworks.com/camshaft.htm
for a primer on what the various specs mean.
I've had a chat with a couple of guys that have run 27x degree cams on their VQ35DEs, and they say they're not big enough. One of my mates put one in a Maxima and, even in a FWD sedan, he didn't feel like it was big enough.
Moderator
Ok, need a quick rundown on cams. What to look for, what the specs mean, etc... Any takers?
This is tempting... but it's too late in the evening for me to begin going down this rabbit hole. If nobody has helped you by the time I get home from work tomorrow, I'll tell you anything about cams that you need to know.
-Ronin Z
Administrator
Discussion Starter #4
-Ronin Z
cool.. i can wait :cheers:
Moderator
OK...
What specificly do you need to know? I will assume you know the basics to some degree... so what's stumping you? I'm lazy and don't feel like writing a book telling you stuff that you might already know.
-RZ
Administrator
Discussion Starter #7
OK...
-RZ
How about assume I know nothing :cheers: because that is the case.
Moderator
Honestly? if that's the case, I would suggest reading that How Stuff Works link (or similar material). I can clarify the points you don't get, or would like more info on.
-RZ
The How Stuff Works link doesn't give pros and cons of duration and lift (the two most commonly provided aftermarket camshaft properties).
I get duration for the most part, but I'm not entirely sure about lift.
Unless you're running cams with a wide enough duration to worry about valves and pistons colliding, what's the downside of running cams with a big lift?
Moderator
There really isn't a downside. There's just no upside either. Once you open the intake valve to about .200 inches of lift or so, there's little to be gained by opening it further. Due to laminar airflow patterns, the intake charge will take on a "tulip" like shape as it rushes into the combustion chamber. As the valve opens further, the charge will maintain this same pattern. It's like opening a can of soda... most of PSHHHHT!!! occurs just as you crack the can open, you don't gain any more airflow opening it up the rest of the way.
In short you want to keep and eye on lift/duration to insure you don't ram the piston into an open valve. This is, as they say, bad.
Regards,
Ronin Z
Administrator
Discussion Starter #12
Regards,
Ronin Z
Would you think me, as a consumer, even need to worry about that? Are there any Cams for the Z that would be designed to be harmful?
Moderator
No, for the most part. There is nothing to worry about as long as you are running the stock (or lower) compression ratio, and the cams are installed "straight up" as in 0 degrees (no initial retard or advance). Things get a little sketchy when you get into high compression ratios, custom spec cams, and/or more than about 6-8 degrees of initial retard/advance*.
Regards,
-Ronin Z
*Installing a cam with an intial amount of retard/advance is often referred to as "degreeing" a cam shaft. This technique is most commonly used in vehicles that do not have a system of variable valve timing. It is used to shift the torque/power peak up or down in the rev range. On motors with DOHC, the cams can be degreed individually. The VQ motor has the ability to change cam phasing (within a narrow range of degrees) on the fly. All aftermarket cams should be installed per the vendor's instructions.
But that's because the air in the can is pressurised but with a finite amount of gas, so releasing it gives the most violent release, but then it peters out because you're running out of gas, so opening the can the rest of the way doesn't give as much flow.
In an engine where the intake gas is "unlimited", I understand that the opening of the valve releases the pressure and gives a sudden inrush of air. But if I open the valve more won't that permit more airflow as there is less backpressure from the valve blocking the hole?
Moderator
When the inlet valve first cracks open, the intake charge “sees” the pressure differential between the intake manifold and the combustion chamber and begins to flow. At first the air molecules take a relatively random path through the valve opening. This initial rush is fairly turbulent and creates a high pressure region around the valve opening. The air molecules closest to the valve and valve seat begin to pile up on one another and the pressure rises. As the valve gap widens, an area of lower pressure develops in the middle of this region and molecules begin to squeeze their way through. Soon air is flowing readily in this area. Air loves to take the path of least resistance. It becomes easier for the air molecules to follow its buddy in front of them than to find their own path. This is when laminar flow begins.
Now if all this was happening in slow motion, then of course the wider we opened the valve… then more air would get through. But we’re talking milliseconds here. And air, like any other object, has mass and mass means inertia. It takes time for the air to get moving. Takes times to begin laminar flow. And takes still more time to adapt to an ever changing orifice size.
It’s because of these tendencies that engine designers tend to focus on increasing valve diameter and cam duration when they want to increase flow. Not lift.
Regards,
Ronin Z
P.S. Sorry about the soda can analogy, but it’s a simple way to picture what’s going on. But you are right, it’s not completely accurate.
note to self....Kenny, stay away from this thread, you don't need cams, although learning about them would be interesting.
+1
I'm very curious.
-RZ
That's where I first 'learned' about cams while reading up on adjustable cams. Good stuff. :clap:
On an FI application would you go for lift?
You don't want to run big duration on a high boost motor, but you want as much of that pressurised air to get into the cylinder as possible.
Moderator
Actually FI has no problem with duration, it's the overlap that is the killer. For those that don't know overlap is when both intake and exhaust valves are open at the same time. Overlap is great for high revving NA motors because it helps scavange the cylinders during the exhaust stroke. Plus the flow-through of the intake charge helps with cylinder filling at higher RPMs. Though it does cause charge contamination and inlet reversion at lower RPMs. This is why NA motors with big cams idle roughly.
Since you have to keep overlap to a minimum (SC is not as upset with overlap as a turbo) this obviously cuts into the max duration you can run. So how do we get more air in with an FI motor? If possible we increase the size of the valves. If we can't do that, we can increase lift... but it doesn't help a whole lot.
Hrrrmmm.... we can't increase the volume of air entering the cylinder.... but wen can increase the density! That's why we're running forced induction in the first place. Get a bigger intercooler and turn up the boost.
Regards,
Ronin Z
Awesome info, Ronin! :clap: :cheers: I think all the details are interesting (note: NO sarcasm! I read it and it could be taken that way.)
Ok. So how do I use this new wealth of knowledge to choose between cam manufactureres? Here's what I found from web shopping:
  • JWT Cams: 260 DEG DUR. / .428"(10.9MM) LIFT, INT. ADVANCED 2 DEGREES.
  • Nismo Cams: 262 Deg Dur. / .426" Lift, Cold Lash - .010" to .013" (WTF is "Cold Lash"?)
  • Tomei Cams (1): 256 duration with 10.2 mm lift
  • Tomei Cams (2): 264 duration with 10.22 mm lift
  • Tomei Cams (3): 268 duration with 10.5 mm lift
So we've got everthing from 256 to 268 duration and 10.2 mm to 10.9 mm of lift, with Nismo listing the "cold lash" -- whatever that means. There must be a reason for having different setups. If I don't care about gas milage and am simply looking for the best over-all power increase, which would you recommend? I'm assuming there's plusses and minuses for all.
1 - 20 of 69 Posts
