I know the answer everyone! Mine too is having the same issues. It is in the transmission. Specifically the torque converter/input shaft. You need to make sure you have new fluid in it though because deteriorated thin fluid will exacerbate this issue. Also if there is an excessive amount of clutch material in the pan you might as well rebuild because to fix this issue you have to get the transmission out of the car anyway.
