<div align='center'>
First I apologize for the vertically challenged dyno graph. I got tired of failing to correct the problem. But the reason I posted was because I was curious about what seems to be unusually low torque #'s.This is the first Z car I've owned. It's the first 6 cylinder I've ever owned for that matter. Coming from an all V8 history mostly F-bodies I felt the stock 350Z lacked the umph that should accompany such styling. So I did the typical bolt ons. CAI, plenum spacer, headers, cat deletes or test pipes as many call them, a cat back system( a little on the large side 3" but it's not dual) and a UTEC with custom tune. I've seen other Z's with essentially the same bolts ons that don't quite make the same HP but their torque is substantially higher. I was wondering if the low torque is due to the overkill exhaust or possibly the CAI causing the intake air to slow too much and is throwing the MAF off. The dyno pulls were done on a Dyna Pack. Any info or feed back would be appreciated folks. So please kindly help a wee old 05 Z 35th with a 5AT that torque is challenged and a member that can't seem to figure out how to insert a pic the right direction. :banghead:
