Guys who makes wheelspacers for the Z
Not universal fitment, but rather unique spacers that are the same size (width) as the hub
Also whats the PCD on the Z?
I tried searching Courtesy Nissan's Website? for wheel spacers, but could only find the bolts. I remember them advertising wheel spacers so I would recommend calling them for further information.
Hope this helps...
I'm not sure if this is up to your qualifications; but I've used several sets (not all at one time :p) of H&R DRM kits.
The DRM is not like a typical spacer. It has it's own studs so there's no lengthening of your OEM studs, etc..
Check them out at http://www.optauto.com <- They have always had the best prices for H&R IMHO.
I am in no way affiliated with H&R or Option's Auto. :)
<edit>
A more direct link:
http://www.optauto.com/index.htm?stocknumber=HR5065662
Not sure if the PCD matches up (350Z same as 300ZX?). But at least all the specs are there for you to read.
Peace.
thanks for the info guys
Tim do u have any pics of the spacers fitted?
chris do u know what size shoulder studs the Z takes, or more importantly what is a shoulder stud? Im looking at the 15mm spacers (which im assuming is 15mm per wheel) and u can choose from 14.25mm shoulder studs and 12.85mm
[snapback]131655[/snapback]​
:dunno: .. just a guess but maybe the studs that are on the DRM kit?
I'll see what I can find out.
