Hello, just bought my first 350z. It has allot of power and great handling. Have a grinding noise coming from the rear of the car. Replaced all my brake system and still does it. Need help, any is much apritiated. Thanks
Be good to have more info on your Z.
Year?Model?
A/T or M/T?
Miles on the car.
The noise you mentioned could be rear end diff,bearing etc.
All the above is critical info to post on your Z. I'd also suggest you take a close look at the rear wheel bearings...
Is it making the noise mostly in a turn?
If so, it may be the limited slip differential. Changing to synthetic fluid may silence it.
