1 - 9 of 9 Posts
When sitting at traffic light or parked the car seems to have a slightly uneven idle... ie the needle moves up and down about .5mm each way (total movement of 1mm). Not a major thing, but it still quite a rev range to raise an eyebrow. I dropped by Pete's place, but he's on holiday and Terry there said that it could be something in the idling circuit something or other. Nothing major he said (and I hope ;) ).
Anyone had that before? I am running BP Ultimate 98RON fuel and it happens after warm up.
I was thinking of resetting the ECU before the drive back to Melbourne, which would give it plenty of time to get back to normal and perhaps get rid of this small annoyance.
I've heard this grounding kit mentioned b4... what the **** is it? :)
Not really... it just idles unevenly... nothing more than that.
Mine did this too at first, then I added a pop-charger and grounding kit, and it smoothed right out.
If you're skeptical, just make your own ground kit with 4-gauge wire.
1 - 9 of 9 Posts
