21 - 40 of 362 Posts
I can't locate the source at the moment, but I seem to recall a common metric being 10 lbs = 1 hp. So removiing 80lbs of stuff mathematically gives your a gross increase by about 8hp, for free. Of course, that's a lot of work and some compromise for a few of the removable items. But it depends on what you're after. 8hp could mean a few tenths in your lap times on a road course.
BTW I've recently lost 35 lbs (Bowflex ROCKS!), so I've already got 3.5 improvement for my car. :irock:
Administrator
Discussion Starter #22
you like your bowflex? thought about getting one.
Do it. If you stick with it, it's amazing how quickly the pounds shed off. I havent moved on to "buffing up" phase yet. But I don't want to scare off the motivation too soon. lol
The fabric seats in your post... were they without the side airbags? If so, how much do you think they would add? I'm swapping in a set of Sparco Torino's which, while heavy, should help lose some weight.
Springs (Stock and Eibach) : I can weigh the stocks
Headers: not taking these off, but hope someone else could chime in
Radiator: why? all of the aftermarket radiators may be lighter, but they hold extra water which will make them heavier
A-arms: The stock A-Arms are paper thin and feather light. All the aftermarket A-Arms are heavier
Swaybars (Hotchkis): There are a few people I know with Hotchkis bars sitting in their living room :) Maybe they will be kind and weight them for us.
When I get around to tearing the z apart I can weight the headers, cats, exhaust, intake plenum and pullies. Then I'll weight all the parts I put on and we can see the difference. Plus I would like to get rims too so maybe I can toss that in there also.
Administrator
Discussion Starter #32
yes, these are for 2003-2005 models.. collected from various sources. Many of which I weighed.
Echo, I already weight the stock exhuast, cats, and plenums
windshield washer resivior. Only a pound at best but is holds a bunch of water and all of it oin front of the front axle.
I cut out he actual grill fromt he bumber cover. about 2#, I also removed all of the metal standoff brakcets that hold stuff in place and replaced them with adel clamps, maybe saved 1/2# but improved appreance and saved wieght. I don't have the weights handy but SS brake lines have to weigh less than the stock ones with all of the bolt down locations. I'm beign anal about it, but I made a promise to a friend that i wouldn't gut the car for a while, but I've been creative in removing weight. Shorter bolts where ever possible and titanium bolts at that. Maybe a savings of 1# but it loks better IMO. lug nuts, I traded weight here, I installed 50 and 60 mm Nismo studs but added lightwieght aluminum lugs and came out about even. for a straight swap 1.2 oz ea times 20. about a 1.5# of rotational mass but is it is very close to the hub. For those with track models or Brembo setups Stoptech Areo rotors, two peice w/ Al hats. Supposed to be a considerable weight savings, again rotational. I didn't notice much weight difference with RSR springs.
Awesome thread. I have a ton of interior parts lying around. I better get to work. Here's what I know now....
OEM headliner = 4.5 lbs
Sound Deadener = approx 12 lbs.
Plus Corbeau Seats has all the weights on their website www.corbeau.com
Corbeau FX1 Pro Seat = 19 lbs.
Could you hang the door panel back on for a minute and LMK if the FX1 touches the door. I put my CR1s in and they rubbed the door panels.
Thanx
Sorry for the highjack
back on topic, I saved ~1 lb by removing the odd standoff brakets used to hold/clamp hoses nad what not and replaced them Adel clamps. Very tedious but looks better IMO.
