1 - 13 of 13 Posts
:wavey: Hi people,
does anyone have a varis air duct on their front bumper?(or any other brand)
what are your comments? (looks, performance),
is it easy to get ther airfilter wet in on a rainy day or when you give the car a bath?
what would b a better decision, using this with a CAI or a POPcharger?
i know, look great, my biggest questions are these tho:
:quote: is it easy to get ther airfilter wet in on a rainy day or when you give the car a bath?
what would b a better decision, using this with a CAI or a POPcharger? :quote:
Getting the filter wet is not an issue, my Injen get seriously wet when I drive in the rain and I have seen no problems whatever. When you wash the car, just don't spray water directly at the hole.
Gains for a duct are a little hard to verify because you need to be moving at speed in order to measure the advantage. Without a wind tunnel, I am not sure it's possible. Aside from that don't expect much, the whole front side behind the grill is a high pressure area with air wanting to get through any way it can.
It has a cool look to it though.
Chris
what would be better, a popcharger with the varis airduct, or a K&N typhoon kit?
Have a look at the Typhoon kit, and what makes it the "Typhoon kit" over a standard K&N pod, and the answer will be self explantory.
the Varis would work best with the K&N or the Popcharger. the CAI is down in such a spot that you would basically just be putting another hole in the front of your car.
1 - 13 of 13 Posts
