Long story short I bought a crapped out ‘08 Z and the headlights were all busted. I wanted to get it registered and needed to replace the headlights. I bought some Spec-D headlights and put them in but here’s my problem. I put the turn signal on and nothing happens. I turn on the headlights and the DRL leds turn on and then I put the turn signal on and the DRL’s start flashing. Anyone know what the correct wiring should be or how to check that out??
Super Moderator
Assuming you simply plugged in the replacement headlights to the factory harness, there's a significant wiring difference for turn signals. I know nothing about what the Spec-D wiring schematic is, but would suggest you examine the factory FSM section on wiring to find a solution. Here's a link to a free FSM for '03-08 Z33 models:
