1 - 13 of 13 Posts
does anyone have a problem with using the remote to open the trunk? it seems 85% of the time i have to hit it twice and be pulling up on the trunk for it to open.
I have that problem because of my spoiler. It added too much weight, so the release springs or whatever don't work like they're supposed to. I have to have one hand ready to keep the trunk open for my remote to work.
I have the same problem when it's cold: oem spoiler and lift gate weight removed. My dealer has a new set of springs on order. I'd suggest you show your service writer this so he can get a set on order for you too. It may take a while.
I think so far I've gotten it the worst. I have to push the button (either on the remote or on the car) anywhere between 3 and 10 times before the hatch will actually pop. I can't even pull it up because it doesn't pop at all until it finally opens. And it's definitely not cold weather, because it seems to be worse when it's warm. Haha. Oh, and no spoiler so nothing altered the weight. One day when I have time I have to bring her in to get checked out.
Originally posted by jinxxycat@Apr 30 2004, 06:51 AM
Hey, where is that lift gate weight?  If I removed it would the hatch open better?  Mine is OK but it just doesn't go up as fast as I would like it to...
The weight is located behind the large plastic panel inside the lift gate. Pop that panel off gently (no screws that I remember), and you'll see the weight, with it's suspension frame, fastened to the lift gate by 4 10mm bolts.
I had my lift gate springs replaced as well. It took forever for the dealer to get them, but the replacements have a higher spring tension, and I have not had the problem since.
Good luck!
I hadn't had any trouble with mine and then my dad came to town for some family stuff. He asked me to pick him up and give him a ride to my aunt's house (where he was staying). He asked in advance to make sure his luggage would fit in my trunk. It took me about 20 presses between the remote and the car to actually get it open. That was the first trouble I had.
I've had the same problem but it seems it does it more often when it's cooler outside. I've talked to the service guys about it and I got that BS answer "can't duplicate it"! Good grief! Of course you can't duplicate it moron, it doesn't happen all the time. Gees sometimes I just want to slap them boyz!
Anyway, I might have them check on that weight and spring next time I'm getting service. Thanks!
That sucks. Fortunately (as if there can ever be anything fortunate about a problem), there is very little chance they can't duplicated the problem with my trunk. I can't even remember the last time it opened immediately. I think it was about a month ago, before any of my problems started.
I had the same issue on my 2006 350. It might be because the springs are worn out. What you need to do to get around a $40 spring replacement cost is: open the trunk and remove your springs. Next, take the cover off the springs and add a couple coins, I used 3 pennies and a nickel. Put everything back together and the coins compress the spring and make the trunk pop normally. 16 cents total instead of $40.
My uncle's new 2007 350Z project is having the same issue as well. Hope it's just the springs. We'll take a closer look after we finished installing the skid plates and smittybilt rack on the current Wrangler project and clear the garage.
1 - 13 of 13 Posts
