1 - 10 of 10 Posts
I purchased some factory 18 inch chrome wheels that had the TPS monitors installed. Does anyone know if the TPS will work on my 2003 touring navigation with 5 speed automatic?
Thanks,
Den
The trip computer on the Base and Enthusiast models don't have a screen for it. And my guess is adding sensors won't enable a hidden screen
<div align="right">[snapback]106675[/snapback]
Right now the display is only showing the outside temp. I know that I can change the display to a read a couple ofdifferent things.
<div align="right">[snapback]106753[/snapback]
If you press the top of the two buttons on the right of the speedometer, you can cycle through screens. But in the non-TPMS equipped trims, there's no screen to display the tire pressure. I don't think adding sensors will make that screen show up all of a sudden. I think either the car is programmed to display it or it isn't. But I could be wrong
You won't have that display. All Zs that have 17s in stock form don't have the TPMS screen. That means only the Performance, Touring 6MT, and Track trims had it in 2003. I'm saying that because you don't have that screen now, I don't think you can ever get it
<span style="color:darkblue">The TPMS was only installed with 18" wheels. If you're that interested it in, you should consider picking up a 2005 model. All 2005s come with TPMS</span>
1 - 10 of 10 Posts
