5% tint in the rear. Very useful.
http://www.350zuk.com/350zukfaq.phpTonneau cover is the term normally used to describe an accessory which covers the open area of a convertible car when it does not have a top which can be raised.
Nissan use the term differently and in two ways:-
There is a small piece of trim made of plastic with a mesh insert which is fitted as standard to the underside of the hatch. When one looks through the hatch glass, this blocks the view into the boot.
Because it is still possible to see into the boot from the front of the car, Nissan also offers an accessory called a tonneau cover. This is a plastic cover which can be fitted underneath the strut brace using supplied brackets.
You must have some hardcore criminals.As to tinting - yes, useful. But I'm sure many thieves armed with torches if they're looking to smash windows.
a torch, we name multiple things the same so as to reduce the size of our dictionary.... but it is interesting that you should think that a crim would break into your z with a blow torch, thats a determined crimlol
Well then, what is a cutting torch called?
:rolf2:
