I have 245/35R19 on the front but having issues with them and need to replace because one is going flat.
Can I fit 245/40R19 without a problem? I don't have any rubbing now, just don't know what the limit is and such when the suspension and range of motion comes into account.
Thanks in advance, and yes I searched this forum for that tire size... didn't find much of anything :)
That new tire size would go better with 18" wheels if you were trying to stay close to OEM specs. Have you found any tire that size? Did you use Tire Rack's tire calculator? I haven't checked it in a long time, so I don't know how accurate their's is compared to others.
edit: try this calculator: http://www.miata.net/garage/tirecalc.html
If you have VDC, you probably don't wanna do that. Otherwise, there shouldn't be any issues with it. It may look kinda funny because the sidewall might be taller than your rear tires depending on what you have in the rear.
Discussion Starter #4
The rear is 275/45/19. I believe.
I doubt I have VDC since it's an 03 base model... so I don't think they have many bells and whistles on mine.
I'm not worried too much about stock spec since the rears are Runflats, and the weight on those is going to be humongous compared to stock... My biggest concern is the fit with a stock suspension.
I also came across some 255/35/19, but not sure how much wider those will be and don't want it sticking out PAST the fender.
You should be fine with the 255/35. What are the offsets on your wheels? What kind of wheels?
As Smooth mentioned, you won't have issues with the suspension with either of those tires. And you don't have VDC if you have a Base model. The big question is what's the width and offset of your front wheels. I have 255s on my fronts (19x9.5 +17) with no issues.
