1 - 20 of 22 Posts
After reading numerous posts of people with the tire feathering issue I was wondering if there was anyone at all with out any problems with an 03. Of course people with the issue are going to talk about it, perhaps those without the problem have nothing to talk about?
my Z's born on date is 10/2002, supposedly the worst with the tire feathering issue. Put 10k miles on it since i got it in may and no signs of trouble - not stock tires tho - avon - tires that came on it, so maybe previously they had trouble? not sure, but i can say for certain that i have had no issues.
My 2003 Track - Born 05/03.
Just got 3rd pair of front tires from Nissan last week.
No Charge for tires or 4 wheel alignment. :rolf2:
Re designed REO40's from Bridgestone to reduce feathering problem.
Nissan has given 36 Month unlimited mileage warranty on 03-04 for tires and alignment.
Only noticeable effect of feathering is tire roar.
Alignment is the secret as mentioned above. It is absolutely necessary for the toe-in of the front wheels to be set to the "prefered" setting published by Nissan for this problem That setting is .1 degree toe-in for each front wheel with a total toe-in of .2 degrees, +/- 0 degrees. That has gotten me 14,000 miles on my summer wheels/tires (Michelin Pilot sport PS2) with no feathering at all and from the looks of remaining tread, another 10 to 12, 000 miles left on them. Just changed them out for my winter wheels and tires.
BTW, I went through 2 sets of the original Bridgestone tires on the front before getting the alignment right and when I pulled the third set off (had 5,000 miles on them) to put the PS2s on, I had no feathering at all on those tires either.
There is a” Class Action Lawsuit" page on the web.
It is taking names of complainers so the law firm can get millions and Z owners can get a $5 check.
Since Bridgestone has built a different REO40 for the Z, with "less aggressive edge design" and several on this site have cured the problem with different wheels and tires it might well be a simple tire design conflict.
Good post! ^^ :shiftdrive:
ummmm
you got an 03?
hmmm
yup feathering problem
That's such a generalization. :nono:
That's true.
I got new tires for the front this past summer. As others have said, Bridgestone made a different tread which eliminates the tire roar. I don't know about feathering issues with the new tires, but as another member stated, alignment is the key. Mine was way off when I got my new tires put on, and Nissan corrected it.
1 - 20 of 22 Posts
