1 - 20 of 20 Posts
I love my new 2006 Enthusiast Coupe, but it seems like the things I want to do to it that were easier on previous years may not be so easy to do anymore. I can't find very much FAQ out there yet for the 2006s, probably because they are too new, but here are some of the mods that I want to do right away but am unsure of:
Stock Radio---I want to add an Aux input to the stock radio to hook up an Ipod; This was done easily on previous years using a cable like AUXINSS, is there something out there that will work for sure on a 2006 stock radio (non-bose)?
Billet Grille--2006 has a new front grille. I want to get a billet grille. On previous years, I think it was an easy bolt-over existing grille, but on 06, the only one I see on courtesyparts.com, says it requires cutting the existing grille. Anyone know what is involved in putting in a billet Grille on 06?
So far these are the first two mods I would like to do. Hopefully I can do them!
did something change on the 2006 radio? I dont think the front grille is that much different that you cant use previous billet grilles
"PLEASE NOTE: Cutting of your existing grille is required to install this item.
You will not be able to use the Nissan Nose Mask with this grille. "
more of a hassle....
if you wanna do it, start cutting!
it says the same thing for 2003-05 models.. its just that grille.. there are other ones that dont require cutting
what about CAI?
Plenums?
and so....
they should be the same right? all bolt ons
I believe the plenum is different. It is the same as the anny edition.
i remember when i had my CAI installed , the guy i purchased the item from said that 03 CAI for the Z are different than the 05's
hmmm, not sure....
There are other grilles that you can install w/o cutting the stock one out. It is just that particular grille, and I am sure you can use that one w/o cutting the oem one out, just a little improvisions.....
here are more grilles, T-Rex brand:
Any links to the grilles that won't require cutting and will fit on 06? Thanks!
link link2
even if they say you have to cut, you may not have to. A lot of these grilles are simply installed w/ nothing but zip ties holding them on....the difference btwn the 03-05 and the 06's is the # of horizontal bars in the grilles, and that is all I believe. w/ some improvision you should be able to make really any of them work :dunno:
okay i've got the billet grill and i dont really like how it sticks out so much. i took it off and it looks like the stock one except its got this big gap in the top center where i guess the license plate is supposed to cover. i want to try and push my grill back a little so it looks like this
right now, mine looks like this
i have these pieces but the silver things are a little shorter (maybe thats why its sticking out so far)
do you guys think its possible or would i need to cut it and somehow remove the original grill?
Discussion Starter · #17 ·
hey deviljon how did you install your grille? did you have to cut the stock grille or does it just go over the existing, and where do those brackets go?
i bought my car with it, its connected by some hooks and screws that connect to the original grill. all it is is 4 screws and hooks. for some reason, my original grill looks a little funny, i can show you a picture of the parts and what my original grill looks like,
and here's the parts:
Discussion Starter · #19 ·
I wonder what is involved in cutting up the stock 06 grille? I e-mailed some guy online that sells the 8 bar grille and he said the stock grille needs to be cut out. It will probably give it more of the set-in look and won't stick out so far
I also inquired about the T-Rex grille. There's a pic here: http://www.trexbillet.com/index.php?sku=92...=101&dealer=no; It clips on to the existing grille, I think it's ugly seeing the stock grille underneath...plus I don't like too many bars.
1 - 20 of 20 Posts
