Discussion Starter #2
I have a question about my 2004Z Roadster. The driver side window won’t go up or down. Is replacing the motor the only option? Thanks
Super Moderator
Hello Chuck- your question about your '04 ZR depends on whether you have ever replaced the DS window motor previously. If not, the problem is likely the motor, as this is a common problem. Check the window switch to make sure it's not the cause.
