I had taken y motor from my05 G35 and put it in my 03 350z there was nothing wrong with the motor when I finally got into the Z I got a no crank no start the starter is fine it clicks but won’t turn then I tried turning it with my hand and it’s locked up now I have the car jacked up if I can turn the back wheels shouldn’t the motor also turn
Discussion Starter #2
Super Moderator
Driveline tension and compression will probably make turning the rear wheels impossible if the clutch is in. To turn the engine over manually, you'll need to put your Z in neutral and use a ratchet and socket on the crank pulley.
The click is just the solenoid - not the starter
The battery could be low
The starter may not be engaging the ring gear - also preventing the current flowing to the starter
As per the reply from dkmura, put the transmission in neutral and use a spanner on the crank pulley to check the engine rotation
