1 - 11 of 11 Posts
I don't need to go all out for performance and get a full exhaust, I just want to kick up the stock deep exhaust tone. Will test pipes do this?
Obviously, I don't mind having a bit more power, I just don't have the $$ right now to shell out for a full Borla or Magnaflow.
Other than a popcharger and plenum spacer, any suggestions for the exhaust?
Resonated TPs or hi-flow cats should do the trick.
I used to have the Helix straight pipes, which some people didn't like due to the raw sound. I didn't mind it because it only made the rasp at a certain RPM range.
I now have a cheap set of resonated pipes which doesn't sound the same but is still loud enough for me.
Discussion Starter #5
QUOTE (SmoothZ @ Jul 26 2009, 07:33 AM) index.php?act=findpost&pid=580892
Couple questions for you sir:
1. For clarification, is the "rasp" that sound that people feel is ricey?
2. Raw sound? This sounds like what I'm looking for minus that certain rasp at X RPM, isn't it?
3. How cheap a set of resonated pipes, what kind and most importantly.. have any vid/sound clips of the resonated or non resonated?
Thanks mucho!
With the new resonated pipes:
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i8.photobucket.com/player.swf?file=http://vid8.photobucket.com/albums/a13/SmoothZ/exhaust%20systems/singleexhaust003.flv">
The rasp usually occurred about 2500-3000 rpms, then went quiet. The raw sound I mentioned is more like the sound you hear at a race track like certain SCCA events with built motors and true amateur cars.
I think the majority of pipes cost between $100-200, and the hi-flow ones are at least $50-100 more.
Discussion Starter #7
QUOTE (SmoothZ @ Jul 26 2009, 12:19 PM) index.php?act=findpost&pid=580917
Wow, thats stock exhaust, resonated pipes?
Top Speed resonated test pipes, a bigger y-pipe, stock mide-pipe with the OEM resonator, and a Bosal fart can w/o a silencer. I call it the Frankenstein exhaust.
Discussion Starter #9
QUOTE (SmoothZ @ Jul 26 2009, 08:20 PM) index.php?act=findpost&pid=580941
What size is the factory y pipe? I don't want to get one smaller than the factory one, but I want to know that the inlets/outlets match up.
pretty much the same setup as Dave minus the Y pipe and with helix non resonated instead....
with the helix i only hear rasp when i let off the gas and it goes dvown to the rpm's he listed... getting on it... nothing but sweet sweet exhaust note
1 - 11 of 11 Posts
