1 - 9 of 9 Posts
04 350 I have had it about a month. I had to add a quart of oil today. Initially the car had a valve cover gasket leak. I got it fixed and topped off oil. Now I am adding and not seeing any on the ground, but I can smell oil at times when driving. Is this common? Starting to look for another engine.
Super Moderator
Welcome- the first question is how many miles are on this Z? Did you do a leakdown or compression test before buying it?
Super Moderator
130K miles is quite a bit of mileage if the VQ35DE wasn't well-maintained. Any maintenance records? I'd also check to see if the valve cover gaskets aren't leaking oil around the spark plugs. Plugs should've been changed at 100K.
I just had my valve cover gaskets replaced also. It will take a while for the oil that had previously leaked to burn off so i would give it a while before i started to think about doing anything drastic. Most likely the shop you took it too didn't clean off the leaked oil. Mine still smelled for a couple weeks after the replacement so i wouldn't be to overly concerned unless of course it doesn't clear up soon. Just give it a little time
2006, 350Z track
Got a question. I have a 2006 350 Track, 31,000 miles. Nissmo exhaust, Nissan cold air induction and new Michelin tires. Daytona blue, not a scratch on it. Garaged in heated garage.
Anyone have a clue what it is worth?
Thanks
Super Moderator
Valuation questions depend on where you live. Why not start a new thread and post the question along with your location or zip code to get an answer? This thread is about oil burning and possible repair.
Thanks
Does it look like mine? Factory spoilers etc.
1 - 9 of 9 Posts
