Is this common? I leave some paper type inside there over night or for a while and it leaves a stain light residue like its wet or something. It's not wet but leaves a grease like stain upon the paper material.
For instance paper I leave in their becomes darker on some spots ad I left a cardbox white box and the surrounding sides on the box had the same grease like residue.
That's strange. I bet if you take out that compartment and clean it really well with a 50/50 mix of Simple Green and water, then let it air dry for a few days, it might get rid of that problem.
Oh, and I fixed your title.
Thanks.
I'll try that. I'll try and get a pic of what I'm talking about. It may be nothing but idk what would cause it.
Right below both the sub woofer and the glove box behind the passenger side of the Z are the gas tank / level indicators (floats). There are about 6 bolts around a ring that holds each in place with a rubber gasket between the ring and the tank. The one behind the passenger seat is easy to get to by removing the glove box. I would check to be sure you don't have a very small gas leak. The next question is, do you smell anything after a spirited drive with your car? Just some thoughts...
