[/quote]
The hood fits great!! Only small issue with the hood prop. For now, I just remove it to shut the hood and place it in the trunk. But, I am sure I will figure it out.
As far as hood pins are concerned, my body shop made a small cable with tie downs on the inside. So, if the hood popped open, then I have a small cable to hold it down. I will have to post a pic, its kinda hard to explain. So, I don't have to use hood pins now.
<div align="right">[snapback]92834[/snapback]
[/quote]
ever thought of the hood shocks? those would be pretty sick if it would work out.
also, hood pins would look good on it!!
did you ever contact nazar?? if you're heading up to NH to get it done....call me...i wanna see your car!
<div align="right">[snapback]93025[/snapback]
[/quote]
I have tein hood shocks, in fact they're even painted "GReddy Blue". But, I think I would have to lose my battery and brake fluid covers that I like so much. I have been thinking of just getting them modified to fit the dampners, but just don't have the time right now.
I like hood pins, but don't want to drill that gorgeous hood. Once you drill it, I can only imagine that over time it will get air, dirt and all sorts of crap inside the CF....eventually destroying the hood.
<div align="right">[snapback]93091[/snapback]
[/quote]
yeah....just modify the areas surrounding the covers. you don't actually have to modify the covers i don't think. i think they would like awesome on there!
i agree about the hood pins. they would look great....but might cause more problems (unless you sealed off where you drilled the holes and made them small enough or put some sort of cloth in there that would hold tight around the pin).
looks awesome man!
