1 - 18 of 18 Posts
I ran a search but no luck....
Alright who has done it(rolled their fenders) and how easy or hard is it to do?
I need to roll my rear fenders......I a did it on my interga before but I didn't give a rats azz about that car
My Z on the other hand...well....she is my baby soooo need to do it right
thank for the help yall can give me
I looked into it for a while. My driver's fender was rubbing forever. The places around here wanted way too much to do it, so I ended up taking some vice grips to it. You have to be very careful, it takes a lot of work if your tool is too big, and it's not recommended by anybody. If I had the funds when I needed them I definitely wouldn't have done it myself, and it's not a great job either.
A speed shop down the street from me and a local body shop i asked could both roll them. :thumbsup:
Hope this helps.
I am freakn shreading my rear tire so bad...strips of rubber is coming off...I am going to attempt this today....I will tell you how the results are after I do it.....
thank for the help.....I had to build my confidence up a little bit to go do this
My tires were doing the same thing. :werd:
Use the smallest pair of vice grips you can find. I couldn't squeeze hard enough with pliers.
It's not easy, and it's not something I would want to do again for sure. Post up in here if you need any advice or run into any problems. :thumbsup:
when i get my wheels i think im going to have to roll my fender, the offsets seem just too big.
+30 front
+35 rear
on 20's
but that good info Chris, first time i see a diagram of it.
You offsets are too big in the wrong direction.... you are going to rub on the suspension , not the fender lip. If you rub.. you are still stock ride height.
Keep the receipt for those wheels close by. :wink:
stock height yes....
i already spoke to the guy and told him if they rub, he is keeping them.
so im not really worried about that.
the thing is Savini themselves gave those offsets based on the car.
1 - 18 of 18 Posts
