181 - 200 of 208 Posts
So what's the reasoning behind replacing everything? Are you unhappy with your current setup? Are the components not working well?
Discussion Starter #182
QUOTE (SmoothZ @ Sep 12 2009, 02:52 PM) index.php?act=findpost&pid=583360
Well I want a built motor so I can actually used the GT28's! 10psi is no where near full efficiency for them. With having a built motor I need to upgrade certain other parts; EMS, Clutch, Flywheel, other supporting mods. As far as the other stuff I just want a larger BBK, full coilover set-up, & better audio.
Sounds like you're going to have a heck of a garage sale going soon. I'll be looking forward to that.
Discussion Starter #186
Atended my school's (UTI/MMI) Car show/ Dyno day. Took first for "Best Import" and Dyno Results below.
Best Peak WHP: 421
Best Peak WTQ: 361
4th Gear 2k+rpm Pulls 10psi
Notice how flat those lines are!
Who tuned your car? Is this one of mark's tunes? Those power curves are very flat. Im jealous.
Got a few other questons. PM me if you get a chance.
Discussion Starter #189
QUOTE (ashtrojan2008 @ Oct 31 2009, 08:00 AM) index.php?act=findpost&pid=585853
Yeas, Mark did the tune. Nothing against MArk but I think the kit makes the flat power band. It was just as flat before his tune. PM me your questions.
I want that kind of torque.... the hp I could do without. I'd be happy with about 330 to 360 whp.
Discussion Starter #191
Well the JWT clutch started slipping about two weeks ago. Replace it with another JWT clutch & flywheel friction plate. Got 30k(+/-) miles outta the first one. Can't complain with the abuse I sent to it. LOL Hopefully I can get similarly mileage out of the second. Or till I build the motor.
I was about to say.... then I read the rest of your post and saw the mileage and abuse comment. At least you're enjoying it and driving it like it was meant to be.
Discussion Starter #193
Yeah... I'm happy with it. Is there "better" out there, most likely. But for the cost I feel it did it's job well.
On different news... Had to replace my front tires. Most of the time I back into a parking spot. Well I was running late and pulled in quickly at my bank. Left the wheels turned hard right. As I was walking back to my car notice the inside of my pass/front tire's steels were showing. All the way around the tire. :eek: Checked the driver side and same issue. So stopped at Discount Tire today to buy a new front set of KDW tires. Told no ETA. :xZ!o: Well I didn't feel safe driving the car with the tires in that condition so had them mount a set of Falken FK452 245/35-19's. Not as wide as the KDW (255/35) but I feel safer in the car. So now I need to get my car re-aligned. Price you pay owning a modified vehicle. :lol:
Discussion Starter #194
Update... Go Big or Go Home!
Little update;
I have less than 10 payments on the car itself and hopefully I get a job I applied for and it's game on. I've decided to stick with the VQ35DE and do a complete Cosworth build.
Cosworth Short Block:
New Nissan VQ35 Alloy Block
New Nissan Forged Crankshaft (81.4mm)
Balanced to within .5 gram
Cosworth Forged H-beam Connecting Rods
Cosworth Forged Pistons and rings (95.5mm)
Cosworth High performance Rod and Main Bearings
Cosworth High Performance Main Bearing studs
Complete blue-print assembly
Ring gap set
Bearing clearance set
Deck height set
Connecting Rod side clearance set
Crankshaft end float set
Complete balancing of rotating assembly
Cosworth Heads:
CNC Ported/Machine finished port
Intake 19% (max) increased flow
Exhaust 22% (max) increased flow
4-angle Inlet Valve job
3-angle & radius Exhaust Valve job
Back-Cut Inlet Valves
Heads are Ultra Sonic cleaned prior to assembly
Heads are Serialized and sport a machined Cosworth logo
+1mm Stainless Steel Intake Valves (1800 degrees max.)
+1mm Inconel Exhaust Valves (2400 degrees max.)
Performance Valve Springs
Titanium Retainers
Hardened Steel Spring Platforms
Knife edged port divider
Combustion chamber volume 58.5cc (OE approx 56 cc)
Cosworth ZK1 Grind Cams:
Intake "268" deg. 10.4mm lift / Exhaust "268" deg. 9.5mm lift
Cosworth VQ35 High Volume Fuel System
O-ring fittings
Compatible with original or aftermarket injectors
Fully configurable
Sleeved high pressure fuel lines
CNC machined distribution block with auxiliary port
Tuning will be completed by the;
HalTech Platinum PnP Standalone Engine Management System
· End User Tunable (not locked like some EMS on the market)
· Sequential Fuel and Ignition Control (32x32)
· Complete Intake and Exhaust Cam Control ('03-'05 Intake Cam control only) (24x24)
· Cylinder Trim Tables for each injector and ignition coil (8x8)
· Configurable AXIS and Load points for all tuning tables
· Tuning via MAF, TPS, or MAP
· Fuel tuning by Volumetric Efficiency (VE) or Injection Time (MS)
· Open/Closed Loop Boost Control, with wheel speed and wheel slip adjustments
· Dual Channel Closed Loop 02 Control
· Map Trace
· Onboard Data Logging
· USB Communication (no outdated Serial cable required)
· New Windows Tuning Software, ‘Haltech ECU Manager’
· 32Bit Microprocessor, 55MHz
· Plug and Play Loom
· User defined rev limiter ('03-'04 only)
· Auxiliary two-step rev limiter
· Knock Detection
· Overboost Protection
· User Configurable Inputs and Outputs
· Nitrous and Meth Injection Control
· Nissan/Infiniti CAN Communication Integration - provides individual wheel speeds, steering angle, G-force, yaw (on applicable models)
Haltech Dual Channel Wideband AFR Kit & Haltech Boost Control Solenoid Kit
Upgrading the Exhaust;
GReddy Racing Ti-C Cat-back
Full dual 70mm w/ dual mufflers
Also upgrading the BBK;
StopTech Trophy Sport Kit
Fully forged aluminum construction with hard anodized finish
Patented, bolt-in bridge minimizes caliper compliance for a firmer pedal
Stiffest 6 Piston caliper currently on the market
Uses standard FMSI D1247 pad
ST-40 uses standard FMSI D372 pad
Front & Rear floating 355mm x 32mm rotors
ALL finished parts are 100% leak down and pressure tested to 2500 PSI
Uses a popular pad shape readily available in over 15 street performance and race friction compounds
Over 19 different piston size combinations available to tune brake torque to the needs of each individual application
Differential piston sizes minimize pad taper for longer pad life and a firmer pedal
Dust boots are standard for reduced maintenance on Sport Trophy Kits
Lastly I'm doing a complete suspension upgrade of all SPL components and coil overs from Tanabe.
Tanabe Sustec Pro SEVEN with TEAS
SEVEN advances the technologies and greatest strengths of previous high performance Tanabe suspensions like the RR & DD even further. While similar in appearance, the SEVEN is completely different from any suspension currently available. The difference lies within the suspension itself and its highly unique internal construction and slide valve technology.
The new slide valve technology allows a great range of adjustability and function from both sides of the performance spectrum. (comfort to pure competitive motorsports use)
When used with the new TEAS electronic active suspension controller, the wide range of dampening force is accessible through the touch of a button, and is fully programmable to automatically adjust dampening rates according to the speed you drive.
When used with the new TEAS electronic active suspension controller, the driver can program TEAS to automatically adjust Sustec Pro SEVEN - HARD DRIVING version to automatically change dampening force based on studied entry and exit speeds of various turns, as well as average lap speed.
And lastly... My 3rd gear went on me over the weekend. So I'm thinking of adding the OS Giken close ratio gear kit;
OS Close Ratio Gear Kits are produced for those seeking improved drive train performance and faster lap times. Gear ratios are carefully calculated for each application for the sole intention to improve your transmission's performance, and maximize your engine torque band on the track.
Each OS gear has been carefully designed and created using selected only forged quality materials, for extra strength and durability. In addition to using forged materials, gears are also hard shot peened for increased strength, load capacity and reliability.
1st 2.783 / 2nd 1.961 / 3rd 1.507 / 4th 1.217 / 5th 1.000 / 6th 0.812
dang son...
I am so jealous right now. Keep living the dream Robert. Will you be making it a high rpm screamer or will you stick with the lower redline for the sake of "longevity"? With those Cosworth heads and the balanced block there shouldn't be any reason not go high rpm unless the turbos lose power that high up the band....
Discussion Starter #198
7500 is what we're currently thinking.
Discussion Starter #199
I've honestly have been flip-flopping on selling or keeping the Z. Right now IF I was to sell it I'd want to buy a new GT-R or CTS-V. However I just can't justify that large of car payment. So I getting back to building my VQ. Been talking with Kyle & Brett over at Import Parts Pro for several months (going on over a year) now. Sent Brett the below list of what I think I want.
~ IPP Stage 3 Long block with Cosworth Pistons (8.8:1) & Rods, JWT C2 Cams
~ Ceramic/Moly Coated Pistions
~ ARP L19 Head & Main Studs
~ Pathfinder Cooling Mod
~ Nismo Termostat
~ ATI Damper Pulley
~ Cosworth Fuel Rail Kit
~ Aeromotive 340 Fuel Pump
~ 2004 6sp Nissan 350Z Transmission
~ Carbonetic Twin Disc Clutch w/ Flywheel
~ IPP Chromoly Clutch Pivot Ball
~ Nismo Roller Bearing
~ Quaife LSD Differential Manual
~ SPL Solid Diff Bushings
~ Greddy Turbo TI-C Exhaust
~ Haltech Platinum Pro EMS
~ Haltech Dual Wideband Kit
~ Haltech Boost Control Solenoid
~ Injected Performance Dual Wideband Guage for Haltech
~ Koni Shocks
