Good morning,
Well, I received and installed my B&M short shifter in early January. It was on my mods list and someone gave it to me as a christmas present. In truth, I really didn't think it was necessary, but I thought I would give it a whirl. Initially, I did not provide a review of the item because I knew on the first drive that it would not be a cut and dry install. Well, I was right.
Installation
Overall, installation is a breeze. It is a little tough to access the bottom of the shifter because the drive shaft is in the way. Also, my dual Borla exhaust pipes down help either. However, it is still pretty easy.
One thing about the B&M instructions that troubles me is the need to file part of the shifter housing. You need to file down some of the aluminum for one reason or another. I think it is so you can get into first gear. However, the instructions for this step are not clear enough.
Also, the instructions state that you SHOULD NOT use this little metal spacer that is just under the shift know. The spacer is there to keep the shift know from grinding into the shift boot when you tighten it down. I disagree. That spacer should be used.
Driving First Impressions
Right off the bat, I was pleased with the new throw. It was shorter without being ridiculous. Also, the shifter had a nice positive feel. When you shifted into gear, you could feel a nice positive lock. Nothing was particularly smoother, but it worked well.
Unfortunately, I also noticed is buzz right away. The shifter buzzes in the upper RPM range. However, it can be tuned out with a loud stereo. But, it is definitely annoying. I asked around for a solution, but no one had one. However, I think I have identified the problem. The stock shift cup has a rubber "pad" on the top. The new shifter cup for the B&M shifter does not. I think the B&M shifter cup is vibrating against the metal plate causing the buzz. I have not tested this yet, but I will let everyone know if inserting some rubber there works.
Extended Driving Impressions - THE BAD
Over time, the shifter got down right bad. It was even dangerous in some circumstances. It quickly because apparent that the shifter alignment was poor and the "positive lock" feeling was actually a sign of a poor design. I started to have trouble getting into first gear when only slightly rolling. With my stock shifter I could easily slip into first gear if I was rolling very slowly. Forget that with the B&M shifter. Also, both shifters there is a small square metal "tab" sticking off the side of the shifter shaft. This metal tab rides against the side of a metal plate when in 5th and 6th. It prevents you from going into reverse by mistake. When you press down, this tab will slip under the metal plate and allow you to access reverse. On the B&M shifter, this tab cause serious problems with getting into 5th gear. It made it a struggle. With care, you could do it, but it was not easy enough. Also, the tab WORE AWAY to the point where I could hit REVERSE AT ANY TIME. This is bad. I could not go from 5th to 6th without risking an accidental reverse. Thankfully it never happened, but I still had to be very careful. This also meant that when I needed to downshift to 5th for power on the highway, I would frequently misshift and not be able to get back into gear.
The Fix
Cheston/Chebestos is sponsored by B&M and posted that B&M has come out with a version 2 of their shifter. Apparently, they redesigned the tab on the side of the shifter shaft and made some noise corrections. So, I wanted to take a look and mine and see if it had serious issues.
I opened up the shifter and sure enough, the metal tab was worn down severely and there was metal flakes all over the inside of the shifter cup. I contacted B&M and they gave me a return authorization. I am shipping it out today.
I fully expected to get a version 2 back in the mail in a couple weeks. When I installed my stock shifter, it was like butter. I glides into all the gears and I only need a finger tip to shift. Sure, it is not short, but it is accurate.
When I get my shifter back and test it, I will update this thread.
Cheers y'all!
Installation
The Fix
Cheers y'all!
