I came across a pdf file for resetting your ECU, so here ya go
[snapback]88576[/snapback]
</span>A type of bipolar transistor consisting of a layer of N-doped semiconductor (the "base") between two P-doped layers (the "collector" and "emitter"). PNP transistors are commonly operated with the emitter at ground and the collector at a negative voltage.
I have had my mods put on at a tuner shop. Do I need to reset the ECU? Thank-you!I came across a pdf file for resetting your ECU, so here ya go
