1 - 10 of 10 Posts
So the front, rear, and side emblems will all have holes behind them if removed?
What about the 350z on rear top left?
Another question while I'm at it. If the front license plate bracket screwed into the front bumper? Can it be removed or are there holes in the bumper then.
forgot about the 350z - no holes
fender (left & right) holes
rear nissan emblem - holes
front nissan emblem - no holes just a space cut out for the emblem
yes plate/plate bracket - drilled into bumper - check out bumperplugs.com or go to home depot and get the locking nylon plugs - airbrush/paint to match the color of your car and push in the holes
~Z~
Zach got it right, only the 350z emblem is like that, no holes/cut outs. The front plate bracket, what a PITA yes there are going to be holes. What state are you in? Most states require a front plate and therefore the dealer should have put a bracket on there. (thank goodness PA is one of the few one plate states!
[snapback]137504[/snapback]​
i only half to run one plate to, yeah alabama
:cry: NJ requires both!
1 - 10 of 10 Posts
