I am having problems with my Transmission. Would it be ok to have it rebuilt? Money is an issue and Nissan wants 2,200 for a new one. I can have it rebuilt for half that. What do you guys think I should do?
What exactly is wrong with it? Were the specific about the problems? I would rebuild it with some aftermarket parts.
Do I need new syncros? (spelling?)Just buy a new clutch plate and flywheel, along with some good synthetic tranny fluid. If you can do it yourself, more power to you. Otherwise, it will cost you a lot for labor.
+1Just buy a new clutch plate and flywheel, along with some good synthetic tranny fluid. If you can do it yourself, more power to you. Otherwise, it will cost you a lot for labor.
IMO I would replace them. easy and cheep.Do I need new syncros? (spelling?)
I've had my gearbox pulled down recently since I broke 3rd, and I've got some bad news on that front.Do I need new syncros? (spelling?)
Thanks for all the info! I will let you guys know what happpens. :shiftdrive:
Good to know that the rebuild worked out!Well...Everything seems great now. The only thing is that it seems harded to put it in 6th than any other gear. I can tell a big difference in 1st and 2nd when I get on it. It feels like it red lines 1st and 2nd much faster now, and no grinding.
How much did the trans rebuild cost you?Well...Everything seems great now. The only thing is that it seems harded to put it in 6th than any other gear. I can tell a big difference in 1st and 2nd when I get on it. It feels like it red lines 1st and 2nd much faster now, and no grinding.
