1 - 3 of 3 Posts
OK here is my problem.. My 06 Zed's rear bearings are toast after 80k, and since they need to be replaced... I was curious if anyone has swapped or tried the rear 370z bearing assembly on a 350... I think spending $125+ for one side is a little steep for the bearing + hub for the 350... When the whole assembly for the 370 goes for $50-$100 for the pair.
Would be interesting to find out if its even possible on the rear.. its not an option for the front because the center size is different.
Any info would be great.. Thanks in advance everyone.
· Super Moderator
I do not believe the hubs are swappable from Z33 to Z34. Beyond that, $125 for the entire rear hub is not expensive in my view. Unless you are beating on the car, they'll last a long time after they get replaced.
1 - 3 of 3 Posts
