Anyone who has been having problems with their hatch not unlocking all the way when they press the button this will be the cure for it. And it only costs 4 cents and less than 10 minutes of your time.....
Rear Hatch Opening Fix
Here is a very simple fix for the rear hatch not opening and it costs just 4 cents....
1. remove the springs on the car you can just twist and pull it to remove them 1 on each side under the hatch.
2. Now that you have them off twist and pull till the top part seperates from the bottom once more
3. Now drop 2 pennies on each one.. After the pennies are in you must now push the pieces together till it comes together and then replace the springs back in..
