1 - 13 of 13 Posts
Well - I decided to give smoking the lower reverse lights a try own my own. I figure I can always buy new ones and have TOYKILLA do new ones for me if they look too bad!
What I did not realize is that removing the rear bumper is a pain in the butt.
So here are some pics to help you out just in case!
Step 1 is really removing the tail lights and unplugging the lights from the housing but we are going to skip that step - or I will add it once I go to put the bumper back on!
SO
Step #1 removing Rear Bolts (one on each side)
step # 5 remove the clips from the bottom of the bumper behing the exhaust
(which ended up being my last step because I got to the end and realized that they were still there)
they are the little black pop clips that you can remove with a flat head screwdriver
step # 6 I really dont have a good way to explain because I tried everything to remove these clips - BUT I just ended up pulling until the bumper came loose. I would not recommend this step but I knew that I could get new ones at work tomorrow!
All that just to take the rear backup/turn signals out? :F-you:
Good write up though......
1 - 13 of 13 Posts
