Just removed my cats to have O2 bungs welded in for wide-band O2 sensor. My local dealer does not have the exhaust gaskets in stock and will take a week to order and get in. Am I taking too great a risk of exhaust leaks by re-using the gaskets. It's kind of a pain to get the cats off and I'm looking forward to having to take them off again because the re-uesd gaskets are leaking. Has anyone had good results re-using the gaskets? or is it not worth considering?
You can reuse them.. they are the copper type material which is fine.. the only ones you can't reuse is the foil type metal gaskets because they stick to the flanges when you pull them off and they break apart.
