Status
Not open for further replies.
1 - 1 of 1 Posts
i have added this MOD that will allow you to rate other members only once. the way you rate a member is by simply going to thier profile and you will se an option that will allow you to choose a number 1-10. This rating will show up in the topic when you post as a rating under your name. i think this is a good idea b/c it will allow you to rate members and kinda of give other members an idea if they are a valued member. if they have scammed a lot of people out of stuff i would hope he gets a bad rating. And if a member has a bad arating and you arent sure if you should buy from him, you can check who rated him bad and then PM the other member asking why he gave him a bad rating
you can view the top rated members from the welcome panel up top on the main forum page!!
http://350z-tech.com/forums/index.php?act=Rate&code=03
1 - 1 of 1 Posts
Status
