Anyone out there installed a 4 or 5-point racing harness using stock anchoring points and/or without butchering the seats or the floor? I would love to see a drawing or description of how you did it. I know the 5-point anti-submarine version will have no stock anchoring point, but if someone knows how to do it without drilling a hole in the floor, I would be grateful.
If you want to anchor the sub-belt to the floor without drilling a hole, try this. Peel up the carpet and weld a steel hoop to the floor under the seat. This photo is not from a Z but it should give you an idea of what I mean.
I came up with a system that is PCA approved. It uses clip on ends for the lap & sub belts. Only one hole needed to be drilled in the driveshaft tunnel for an eye bolt. This is for a 6 point harness. The outer eye bolt replaces the OEM lower seat belt bolt, yet retains it's use. Here are a couple pix. More at www.BCRLtd.net
Thanx guys!
Anyone with other ideas also welcome to respond. It will be a while before I install the Simpson harness. :yourock:
