1 - 10 of 10 Posts
I've seen lots of people running 245/40/17 front and 275/40/17 on the rear with the stock touring 17" rims. The recomended wheel size for those size tires is more than the rims that they are on, but the people that use it say they don't have problems. Is there any safety or any other concerns that I should be worried about before using those?
did you mean 18" rims since the touring has 18's as opposed to the base and enthusiast that have 17"? reson i say this is because i got NISMO rims in 18" and run the 245/40 front and 275/40 rear.
Originally posted by Cryptonomicon18@Jul 5 2004, 09:16 AM
Touring comes in 17" stock, not to mention also if i got the 18", the nismo ones are still wider (im pretty sure).
yup, the NISMOs are 8.5 front and 9.5 rear. I forgot that the Auto touring came with 17's
QUOTE
Since no one else answered this question I will. Mounting tires on rims narrower than they were designed for forces the tread to "bulge" in the center. Depending on the tire and the air pressure you run, this can reduce the contact patch and reduce traction. It can, and often does, result in premature wear on the center of the tread, shortening tire life.
While it may not be unsafe (won't blow out or roll off the rim), the only real advantage is looks. Do what you wish of course, but if it were me I'd not run a tire on a rim narrower than it is speced for.
1 - 10 of 10 Posts
