QUOTE (BlueDragonZ @ Jan 20 2005, 05:04 AM)
index.php?act=findpost&pid=61750
<span style="color:darkblue">You could also dig it up right here
ECU Reset How To</span>
Cool thanks DiRN, but I guess I won't be needing it anymore. On my way to work tonight I noticed that the light is OFF. :clap: :clap:
The bad thing is I might need to disconnect some things again since I'm not getting power for my XM. :headshake:
i READ TO CASES OF THIS HAPPENING... HOW CAN I FIX MINE... ITS DOING THE SAME EXACT THING!!! PLEASE HELP... I NEED SOME KINDA AN HELP
I FOUND THIS CASE ALSO
"QUOTE(Littlem @ Oct 12 2007, 11:46 PM) *
Has anyone resolved this? I have just developed the same problem. From the service manual, I guess that it may be a problem with the BCM throught the CAN. All the fuses check out OK. Odd thing with the BOSE radio/CD. Seems dead (not even the clock) until I hit the CD eject button. It ejects the CD, the radio panel lights, and it accpets a replacement CD, then dies again.
I finally got this fixed. It took the mechanic at the dealership two hours (@ $140/hour) to open the CAN/IPDM/BCM (and check 20 fuses that are not mentioned in the owner manual), take out the center console and trace the problem from the radio to the fuse box. Pin 6 on the radio wiring harness was not getting power from fuse 6 in the fuse box, in spite of a good fuse and positive light test. The pin in the harness connected to the fuse box was not making contact. How this could have "gone wrong" after five year with no problem is a mystery. He replaced the wiring harness, and everything works like a champ.
Five years with no problem, then this. Luckily, I have a six-year extended warranty. If anyone in the SF Bay area needs a great mechanic, ask for Gary at Stevens Creek Nissan."
