Stock 350Z (manual) with the Pending mods:
1) JWT popcharger w/ heat shield
2) SPL air intake pipe kit
3) Motordyne XL 1/4" Plenum spacer
4) Fujitsobo Front Y Pipe
5) Pro 1 straight y back exhaust
Never did a baseline dyno. What should I dyno approximately?
To give a guess, if your baseline dyno was ~240rwhp, you should dyno around 259 at the lowest, that's in theory. BTW, any pic of the air intake pipe kit?
Thanks for the response. Picture attached. Excuse the red markings.
<div align="right">[snapback]71236[/snapback]
Thanks for the pic, never seen one before.
Let's see... I have the JWT charger, an intake similar to yours, grounding kit, Helix test pipes, and I dynoed at ~251hp. I think you'll do about the same, if not just a few more than me. The stock exhaust is pretty nice, so replacing it doesn't do much except make it pretty to look at. If you're keeping the stock cats, then the Y-pipe won't help much.
