Power steering oil cooler
2888 Views 7 Replies 6 Participants Last post by  Airbag79
Is this a good item to have if you intend on doing a lot of spirited driving on curvy mountain roads or on the track??
Unless I am mistaken our cars already have a power steering cooler. You can see it when you look into the grill area, it looks like an oil or trans cooler.
yes our cars already have one. I dont know the benefits of getting the Nismo.
I think it's there to upgrade if you have wider front tires then stock and go through a lot of twisties. You should be ok if you have the stock width tires.
Will the stock one be ok when I have my 19''s??
NISMO Power Steering Oil Cooler will help when driving the car very hard, but especially if you are running larger wheels and tires up front...
http://performancenissanparts.com/catalog/...?products_id=56
The Nismo oil cooler's only advantage over the stock oil cooler is that it has a larger surface area for increased heat dissipation. Wether this increased heat dissipation is significant or not is anyones guess, most likely unless you plan on racing everyday it is not.
