I know you have seen a post like this before but I do know what offsets are but Im still a little confused. I want to stick pretty close to stock but I would rather have the back like one inch wider than the fronts. My manual says the stock rims are 18 x 8 with 30 offset on the front and back (the front and back rims are th same size). anyway, here are the rims I am going to order as soon as I figure out which offsets to buy. So my real question is do I want to run the 18 x 7.5 with 45 offset in the back and the 18 x 7.5 with 35 offset in the front (I know the width is the same but as you can see they only come in 7.5) or vice versa. Your info and help is MUCH appreciated because I am going to order these as soon as possible. Thanks.
enkei evo 5 bronze rims
