Well since Lucy was starting to show some major swirls after the winter under cover I decided to give this a whack. I used an orange cutting pad at speed #4 on my PC7424. You really need to work this product from a whitish color to clear, and work in small areas. Doing one panel at a time will not do, the product is very hard to remove if you leave it too long. It's like mud if you don't let it break down...found out the hard way...good thing is if it gets like this you can spritz it w/ a QD and remove it w/ a mf towel while polishing. I also had trouble getting it off w/ my random orbital 10 inch buffer w/ terry bonnett, so I removed it all by hand...ugh :ahhh: the shoulders.
How did it work? :clap: Fantastic on the swirls--I can't see a one...almost like showroom new, but it didn't touch any scratches that you can feel w/ your fingernail. All the rub marks from the cover (b/c I was not given the option of felt on the seams, which will be done before next winter) are GONE. Vanished....I give it a 5 on a of one to ten (ten the highest) on a scale for ease of use, but I give it a 9 in results!
