I just want to know if anyone else is having a problem with their passenger floor board getting wet. It only happens when I cruz with the windows down and the A/C off. Well, most likely the A/C off, but the windows are always down when the A/C is off. I'll have to wait to take it to the dealer later this week.
I was having the same problem but i got mine after or while it rained, i found that i was taking in water from firewall valley. (dont really know what to call it). BUT, if you were to take off the top plastic pieces where the wipers are connected, there is a big rubber grommet that allows the wires from the engine compartment to access the insed of the car i sprayed a little rubberized undercoating and sealed it better, GUESS WHAT, NO MORE LEAKS. Well thats a solution if your getting it after or during the rain, mine was soo bad you would hear the water swushing around down there!!! Good luck man!
yep... had the same problem that JealouZ described above.
If you done any mods that require running addition power lead (such as stereo or piggy back for ECU, etc), you probably had to route wire through this grommet. Check it and if it is not tight, fix it. Water problem should go away.
Nissan 350Z / 370Z Tech Forums
