1 - 10 of 10 Posts
A while back I installed my V1 concealed-display in my center console.
But, in addition to all the little scratches that had accumulated over the years, I added a rather ugly one doing the display install (after my STi-R install)...
Then, on the way back from this year's ZdayZ, my stock CD player died. I had some old head units sitting in my garage but they were all single din units. So I just installed two units to fill up the hole. (and added still more scratches.)
My wife had to ask me which radio I wanted for Christmas so she could order it, so I knew what I was getting. I decided a new HU wouldn't look as good in the scratched up dash and decided to try and fix it last weekend. (I wanted to give the paint/dye all week to fully dry)
Before pics..
Cleaned the parts with rubbing alcohol and used this...
While I was moving the car in and out of the garage for some other projects, I discovered that the plastic module I pulled out was involved with a lot more than the climate controls. My dash lit up every light and nothing worked. (No tach, speedometer, fuel etc. etc.)
I decided to connect everything long enough to make sure I didn't hurt anything by driving it like that, and found a problem I didn't want to have on Christmas day. My "service engine soon" light stayed on, even after everything was connected.:eek:
I explained the situation to my wife and she let me open my present early so that I could complete the project and go get the code checked before Christmas.
There was a long list of codes all relating to the devices that didn't work while I was moving the car in and out of the garage. (Just had them cleared)
So here is the completed project....
The color isn't a perfect match, but I like it. One of the flash photo's really exaggerated the color difference, but I thought I would share it just to give people an idea.
One of the 30,000 colors available with this HU...
I should do something like that...
Moderator
Normally when a thread starts with "I painted my console...", the pictures inside usually scar the eye with some horrible paint scheme that only be described as the fevered dream of a mad man. But in this case, it looks sharp. Much improved.
Great work! :thumbsup:
-Ronin Z
It looks like a gunmetal color in the pics- interesting! Regardless, it's a clean-looking job. Well done, and gives me a bit of hope for when I get around to mine!
I think the color difference is fine. The center console in my '03 is a different color (gunmetalish color) than the rest of the dash. I'm not sure if all of the '03s were that way or not...
when you used the rubbing alcohol to remove the original factory rubber stuff, was the hard plastic underneath smooth or all dimpled like the surface layer, and u sanded it down? i've been itching to do this mod but i didnt know if it would require me to sand and wet sand for days..
Discussion Starter #10
I think the texture is part of the black layer, (as apposed to the light colored plastic underneath). I didn't want to loose the dimple texture so I didn't sand anything.
One of the more difficult parts of the prep was masking the three top pods. The gauges come off as one assembly but the individual pods are held in place with two screws and one melted plastic"weld". I removed the two screws on each and pushed the front part down until I could get saran wrap to cover each pod. They were each "hinged" at the plastic weld point. I was concerned that I might break the weld while masking the stuff but all went well while painting.
I did break one of the weld points when I was pushing the top part into place (reinstalling the dash), just as I was about finished.:eek: I had to remove the center piece again and re-weld the joint. My soldering iron minus the tip made a good, blunt "stamp" between the two plastics and looked similar to the factory joints when done.
Other than that, my steps were..
1) Wipe down all areas to be painted with rubbing alcohol. (I read that mineral spirits was the chemical to use but didn't have any on hand.)
2) Three light coats of adhesion promoter.
3) Three light coats of the fabric and vinyl coating.
I did all steps on the plastic part that houses the a/c controls and stick just to get the hang of it. I figured that if I screwed it up badly, it would be cheaper to replace then the larger top half. After successfully painting the small part I moved on to the larger piece.
The required time between coats was very small. I think the adhesion promoter was ~3 min between coats and the fabric & vinyl was supposed to be applied within 10 minutes of the last adhesion coat. I think I used ~3 to 5 min between each of the fabric & vinyl coats.
I also painted the trim ring from the radio install kit.
1 - 10 of 10 Posts
