Discussion Starter · #1 · (Edited)
Have received this error code 4 times, so must be delt with. 2004 350z with Auto with 85000mi.(owned since 07 with about 44k mi) Only happens on the track (never in normal driving). P2135=Throttle Body and pedal position error. I was going to swap out the pedal position sensor on the car ($15) part and cross my fingers, but this part only appears to be available for the Manual Trans. For the Auto, I can only find the pedal assembly ($250). At this point, I need to diagnose true issue, but feel that the TB should be swapped if I am going to roll the dice. The car is stock at this point so TB upgrade and cold air intake would be reasonable thing to do. This car will never be as fast as I would like, but it is fun. Suggestions on how to go forward.
Thanks.
Ed
Super Moderator
To be honest, P2135 has been my nemesis on my 350Z SCCA T3 racecar. You may want to compare the throttle pedal sensor for a manual with the one on your auto since it's cheaper. I have no real world knowledge about whether it's the same, but it's worth $15 to find out. Make sure you perform the throttle position relearn procedure after the install.
Also, are there any cuts or splices in your main wiring harness? I suspect this may have contributed to my Z being down.
Thanks for the response.
I think the wiring harness has not been messed with. Also, I have put about 40K on the car with no problems, but that was on the street. The track environment is the issue. I was looking at several web sites and focused on CarParts.com. I noticed that the $15 part was only recommended for Nissan manuals and some Infinity w/o sport package. After a chat on the site, I was directed to the full pedal assembly $250 and sure enough- recommended for the Automatic Trans. Based upon this, I am redirecting to a more sophisticated method of diagnosis if I can find one.
I can turn it over to the dealership, but I'm thinking that if they say it is the TB or the ECM I have to pull the car as I'm not interested in OEM parts going forward. Also, they may not be able to replicate the issue in the shop. I can get in about 4 miles before the issue appears on track.
Additionally, I have some good resources here. Auto Engineer with electrical experience that pointed to TB at the track and willing to wrench. Considering this as best option and upgrading to 75mm TB and new intake.
Additional thoughts?
Super Moderator
Don't add any new parts until you diagnose and fix the P2135 issue. Don't complicate the diagnostics by adding any new variables into the mix. Can you still drive the Z on the street?
I see, you have a point right there, it could be the reason.
