2006 Base Coupe, 43K miles, JWT TT with Air/Fuel Ratio and Vac/Boost gauges, 2.5" Stillen Cat back exhaust. Second owner (bought '08).
The original owner had the turbos/exhaust installed when he bought the car, then wrecked it at 15K miles. I bought it in Long Beach, CA with a Rebuilt title, had it checked out in San Diego by a Z specialist and drove it to FL in 52 hours uneventfully. Over the years I've sorted a few minor problems and rarely engaged the turbos.
In a normal situation with an up to temperature engine the AFR gauge reacts to engine load/RPM. Now on cold or warm startup the AFR goes full rich, to full lean for a second or two, back to full rich and stays there, independent of engine temp and RPM. Car seems to run smoother as it warms but still with a random miss.
I'm considering changing the plugs/coils and MAF. Seems like routine maintenance at this point. Anything else I should be looking at? Thanks!
